Sledders! The snow might be gone, but the New Horizons update Part 2 is here!
This update opens up the creativity for players on PC to craft their own maps and distribute them for all platforms to play on. You’ll be wanting to take a stop every now and then to refuel your imagination too.
Have a look at the patch notes.
New Horizons - Part 2
New Features
New Level Editor
A brand-new Level Editor is now available for PC players, offering powerful tools for creating and sharing custom levels.
Fuel System
Players can now enable fuel consumption for their sleds, adding another layer of planning and challenge to their rides.
Changes and Improvements
Game Size Reduced from ~13 GB to 7.2 GB
Optimised asset management and organisation have allowed us to significantly reduce the game's installation size. Reduced game size may also improve performance on some PCs and consoles
Optimised RAM Usage
The way assets are loaded and unloaded within levels has been significantly optimised.
Bug Fixes
Continue reading...
New Features
Over 200 different props to use when building your levels
River and lake creation tools for shaping waterways
Integrated Test Drive mode that allows testing from any point on the map
Map labels for marking locations, areas, and routes
In-depth editing tools for creating new experiences
Levels created with the editor can be uploaded through mod.io and played by everyone
Off by default, Fuel consumption can be enabled by players in the enviromental options
A fuel gauge shows how much fuel there is remaining
Gas stations around the map can be used to refuel
Running out of fuel will require a rescue to the nearest gas station
Gas stations are now marked on all maps that include them
Fuel consumption can only be enabled on maps with gas stations
Optimised RAM Usage
RAM usage should be noticeably lower in many situations
On systems and consoles with limited RAM, this should improve stability
Some systems may also see improved performance
Using Photo Mode within a replay now correctly allows you to change the time of day
Characters such as Ä and Ö now display correctly on consoles
The Replay System and Spawn points now works correctly when used on custom maps on Xbox
Continue reading...
