  • 🏁 2FastRacing LIST RACE – November 30th, 2025
    The next 2FastRacing List Race is almost here! Join the action and prove yourself on the [NO-PREP] 2Fast Motorsports Complex track. Hosted by 2FastRacing and powered by BeamHost + BeamMP.
    To register, press the Join Waitlist button in our Discord channel below:
    View Full Event Info/Rules
    Bring your best build, race clean, and fight for your spot on the Top 10 List.
Civetta Bolide Engine Pack! (3.0 onwards)
Civetta Bolide Engine Pack! (3.0 onwards) 3.0
Angry_Bird
Angry_Bird submitted a new resource:
Civetta Bolide Busa Engine - Civetta Bolide with a Hayabusa Engine (with ridiculous power if you want)
I am the same Angry_Bird on BeamNG forums, here is my first mod on this forum, featuring a Civetta Bolide with a Hayabusa-inspired Engine!
NA:
Turbo:
There are three configs, the 'Busa NA, the 'Busa Turbo and the 'Busa Turbo 1000! You can also put a turbo too if you think it is too slow for you, up to more than a thousand horsepower! There is also a 1.7L Stroker Race engine internals option that can push north of 300 HP in...
In near future I plan to put the mod here with more engines aside the Hayabusa engine, I plan to merge my VR38 mod as well as other JDM engines like the VKs, 1LR GUE (model from my ETK 800 V10 mod on the BeamNG repo) and maybe even a V12, as a 2fast exclusive pack!
Mod future remaster plans.
1. Busa needs to reuse Covet 1.5L Parts
2. Engine choices (4 Cyl, 5 Cyl, 6 Cyl, 8 Cyl, 10 Cyl, 12 Cyl)
- 4 Cyl uses Busa 1.5L (Enlarged Block overall for reliability and power) and 2.0L K20 plus 500 hp NA K24 (Separate slot only)
- 5 Cyl uses Cherrier I5 (Audi TT RS engine)
- 6 Cyl uses VR38 (maybe a 2JZ in the future?) (Twin Turbocharged only)
- 8 Cyl uses VK50/56? (Reusing V8 from my 200BX mod) (NA, SC, TT are fine)
- 10 Cyl uses 1LR GUE (Reuses V10 block from ETK 800 V10) (Mainly NA focused power, prolly no turbocharging)
- 12 Cyl uses 1GZ FE (Reuses V12 Block from ETK800 V12 pack) (modified for NA power but capable of turbocharging)
Angry_Bird updated Civetta Bolide Busa Engine with a new update entry:
Future Remaster Plans! (Will change into a pack instead of a single engine)
- 10 Cyl uses 1LR GUE (Reuses V10 block from...
Angry_Bird updated [ON HOLD, MAKING IT AN ENGINE PACK IN NEAR FUTURE] Civetta Bolide Busa Engine with a new update entry:
Engine pack is up!
Engines:
- 1.3L I4 (with 1.7L block option and turbocharging up to 1000 hp!), uses Covet mid-engine model
- 2.5L I5 (with turbocharging only, up to 1400 hp), uses Cherrier Vivace I5
- 3.8L V6 (with twin turbo only, up to 3000 hp), reusing my VR38 Bolide mod on beam repo
- 5.0L V8 (NA and TT), reusing my 200BX 5.0 V8 from beam repo model
- 4.8L V10 (NA and TT), reusing my ETK 800 V10 from beam repo model
- 5.0L V12 (NA and TT), reusing my V12 engines from beam forums model
Too lazy to put...
