  • BeamHost Just Expanded – More Games. More Power.
    We’re excited to announce that BeamHost, our official hosting partner at 2FastRacing, has expanded beyond BeamMP. They're now offering powerful hosting for some of the most requested games by our community.
    Now Hosting:
    • FiveM
    • DayZ
    • Counter-Strike 2
    • Garry’s Mod
    • Squad
    Montreal, IAD, LHR, and SEA locations have already been upgraded with next-gen hardware delivering over 2x performance.
    The Dallas upgrade is coming very soon.
    Use code REFRESH at checkout to get 50% OFF your first month on any game server.
    Browse Plans at BeamHost.net
    Whether you're launching a FiveM server or upgrading your GMod community, BeamHost offers the performance and reliability you need to grow.
Drag Racing Wheel and Tire Pack - Revolution Racecraft
Drag Racing Wheel and Tire Pack - Revolution Racecraft 1.0.1
Foxbody
Revolution Racecraft || Founder and Owner
Foxbody submitted a new resource:
Drag Racing Wheel and Tire Pack - Revolution Racecraft - Huge real-world wheel and tire collection: brands/models, New Bias-Ply Slicks, Drag Radials, highly
It’s time to get your drag on! What we have here is a couple years on&off of model sourcing + JBEAMing along with some creations by our own team, all packaged into easily one of most extensive drag wheel and tire packs to ever hit a game. This required well into the 4-digit hour range to create, so feel free to share your opinions/feedback on this project!
Help Understand This Pack By Reading FAQ Below!
[COLOR=rgb(250, 197...[/quote]
Hey man, I want to take a moment to say that this is a great pack, but I have an issue. The tires dont spawn in at at, All the rims and the rim customization work just fine, but the tires dont work, ive cleared cache 3 times, and reinstalled 4 times. Any tips?
Thanks for the report, are you in the Revolution Racecraft discord? It'd be easiest to help you over chat in there. Discord.RevolutionRacecraft.com
In general, to troubleshoot a mod clear cache as you've done, then launch your game with only that mod active, if it works, activate others until you find a conflict that is happening. Thanks for reporting again I can help you more at our community space as mentioned! 👍
Sidewall on the drag radials spawn chrome
That seems to be a conflicting mod. Try removing other mods and trying again if it works add a few mods at a time until it happens again. Then remove the last few mods 1 at a time to find the conflicting mod.
When I use this mod on the covet it treats it as RWD the tires are big on the rear not on the front. The front has skinny tires.
You are able to change tire with with the second decond to third drop down menu
Good mod but can we get some customization on the grip? Alot of the tires dont have enough grip i cant go as fast on the wheels. Also some of the colors dont change
Hello if you read the FAQ on the mod it explains about the color options. Also the tires are based on real life tire physics. You are able to use vanilla tires in the wheels. Also there's many different tires and compounds built into the pack to try different things like if you are running the drag slicks try the street R compound and it will stick on almost any surface you try it on.
Unable to get this mod to work. Getting an Error to extract inside
If it's the beam loading error just ignore it. That's a beam thing. Then go to a car with 5 lug hubs and scroll to the top of the wheel selection to see the wheel pack.
I see the wheel pack but none of the wheels come up.
You select the wheel pack at the top of the wheels list. Then both sizes. Then brand. Then model. Then you go into tire selection. There is more info on the repo post on how to select them.
When i go to install the folder for the wheels into my main BeamNG folder, it's telling me the file is corrupted. Anybody else having this issue? I need this in the worst way
Where are you installing it?
Follow Manual install instructions.
In the common folder in my main BeamNG folder.
Edit: Nvm, it's fixed. I've installed several other mods that way and they've worked. Never used the mods folder method as i haven't installed many mods manually. Thanks for the fast replies!
